Do I need a angled rear TB Bracket?
Brian83
Oklahoma City, OK
Since installing my SYE and Adjustable UCAs I am hearing some popping like something is binding and when I checked under my jeep it looks like my trackbar is rubbing on the upper passenger side of the fuel tank. After some google searching I found a few places mentioning an Angled rear track bar bracket. I have a trackbar bracket but its just the straight lifted one moving the hole straight up. I hadnt seen anything on this sight mentioning that so I wanted to ask. I am running stock LCAs at the moment and wasnt sure if I needed adjustable ones to pull the axle forward some to get the clearance?
enough lift to warrant an SYE would suggest an angled bracket may better suit the application.
how much lift? do you know the pinion angle?
well you really cannot move the frame side anchor point.
so it's an angled riser and hope it pulls you just enough to clear or you need 2 more adjustable CA's and bring it forward some.
either way the angled bracket is warranted. it'll either fix it or move it as much as possible allowing the adjustment for additional CA's to be absolute minimal.
Reactions: Brian83
