Do I need a SYE?
davidb470
Colorado springs
Im just putting slightly longer shocks and coils on my to (2 inch lift) can I get away without using and slip yoke eliminator kit?
I would think you'll be fine without. Could always do a MML (motor mount lift) to help with the drive shaft angle which would be much cheaper than SYE.
That depends entirely on what the total spring height will total after that "slightly longer" thing you're adding. What exactly do you mean you're installing longer coils to your 2" lift? Is your present 2" lift a 2" taller spring or is the 2" lift a 2" spacer lift?
Exactly what is giving you your 2" of lift now? 2" taller springs or a 2" spacer? What are you adding to the top of that? Spacer? Your "slightly longer shocks and coils" is confusing.
If it is a stick shift and you raise the motormount or drop the skid plate it changes the geometry of the stick. Some people don't like it. And in my case it caused me not to be able to get it into second gear easily. I ended up doing an SYE so I could get my shifting geometry back. Of course you could possibly heat up and bend the stick but I like mine in the stock position.
I just put a two inch lift on the girlfriends jeep from a 3 inch lift and she had a 1" skid plate drop. I hated her jeep but when I swapped out her springs I took the drop completely out and it drives fine. BTW Mine is a 98 and hers is a 2000 both 4.0 ax15 5speeds.
Now that I put the stick back where it belongs she likes driving it much better. I do too. Her drive line is still at a good angle I could probably go another 1/2 inch with no issues. But I would say that is about it. If she wanted to go any more I would SYE it especially if you can afford it. The most expensive part of the job is the driveline. So if you can find a cheaper place locally you might be able to find a better deal, but the total cost I paid for mine was 500 bucks. If I remember correctly it was 300 for the driveline and 200 for the other parts give or take 50.
If it is an automatic I don't think it changes the geometry of the shifter, so you probably wouldn't even notice a transfer case drop or motormount lift.
My .02
