So I am replacing every part of my AC system except for the compressor. Do I need to do anything to the system before I charge it? The old collector dumped a fair amount of oil, but the new one doesn’t have any in it.
Remove the compressor and with the ports pointing downward rotate the compressor in the normal direction of rotation into a graduated container.I was saying collector, but I meant the drier/accumulator. Everything is new but the compressor, I even bought new lines. Is there a way to drain the oil from the compressor?
Yup, the only time an evaporator or condenser need replaced is a leak or a catastrophic failure of the compressor.There are a few good videos on YouTube. Easiest way is to remove the compressor and pour it out, though this may not be practical.
A chemical flush will also dissolve most oil.
Personally, I would skip replacing the evaporator unless I knew it had an issue. It's a lot of work to remove the dash. (If you do, consider doing the heater core at the same time.)
It needs to be under a vacuum for a while before it’s charged. 30 inHg.
I would prepare the system and take it to someone with an AC machine. They can verify it holds a proper vacuum which means it’s sealed and keep it under a vacuum which rids the system of moisture and contaminants and then charge it to the exact weight.
Most compressors I’ve installed come with oil in them.Should I fill the compressor with new oil before taking it in, or will the shop do that?
Just make sure that the shop knows you did not add oil to the system, Typically TJ's take about 8 ounces of refrigerant oil and it must be portioned out to each component of the system. In a dry system the approximate distribution would be 4 oz to the accumulator 2 oz to the condenser and 2 oz to the compressor. Question, did you use the proper O ring lubricant at each of the tubing and hose joints.
So far I’ve only made the connection from the accumulator to the evaporator. I used a bit of the refrigerant oil. Is there something different/better I should use?
If I add the oil myself, do I need to put it all in the compressor or break it into the individual components as you noted?
