Two cents based on the industry I'm in. I work with industrial engine manufacturers. Everything from a 1.5L 4cyl to a 75L 16cyl engine. All the manufacturers unanimously agree that a dry filter install is preferred and they design the engine for it. The only exception being extreme duty engines that have 3-10 oil filters. A lot of the manufacturers I work with design their filters in a vertical design or canister so it drains back to the pan for fast and clean filter changes as there is no oil in the filter after about 20 minutes. This means it starts every time without oil in the filter. Are you doing something wrong by prefilling? Not at all, but it is an extra step. It's up to you.
