I am replacing the timing chain on my 98 4.0 with 180,000 miles. All the engine noise is coming from the timing chain and speeds up with the engine.
the oil pan gasket looks like a pretty new 1 piece unit and doesn’t leak a drop.
if I just remove the timing chain cover will I be able to reuse the oil pan to timing chain gasket assuming it doesn’t get destroyed or should I just be planning 100% to remove the oil pan and replace the whole gasket?
