Thanks! How difficult is that to do? Reason want to avoid the MML is because of the difficulty of install. I'm the furthermost thing from mechanically inclined but really want to try to and do the BL install.
Diifficult to install? It's pretty damn easy. Then again, if you aren't even remotely mechanically inclined, I would say forget it. But if you installed a body lift, you can install a MML.
The AC obstruction is easy, there are 3 bolts that hold the motor mount plate to the block loosen them the whole mount will rotate enough to get that bolt out.Thanks everyone for the info. The video of the install of the MML with the AC obstruction scared me off. I may reevaluate and give it a go anyway after I check for rust.
Body Lift is definitely easy. The hardest is probably the one puck by the gas tank. Oh wait, I think the hardest thing about my BL was the fuel tank filler hose. Probably took me just as long to do that as to do the BL since I couldn't get the thing to break loose.
Motor Mount lift was not as easy. It also requires jacking the engine up WAY more than I thought (do it from the oil pan).
Jeep is not as fragile as I think it is sometimes. I ultimately figure it out but I am sure I go way slower than others. When it's your first time it can seem daunting, but just get started on it and you'll figure it out.
I would not jack up on the oil pan. I use the trans flange where the block bolts to the trans to lift.
Chris you'd rather install motor mounts than move the fan shroud down a tad?No, but IMHO you'd be smart to do both unless you want to deal with the fan shroud.
On a TJ Unlimited?Only because I would take any extra pinion angle help I could get from the MML
