Yes, just drill from the top down with a good 3/16" drill bit. You'll struggle finding the right speed to hit it with that just doesn't start spinning it.I am attempting to install a purchased subwoofer box because mine came with the deep plastic bin instead of the subwoofer option. May I ask how you drilled them out? Just from the top down?
Thanks for the info, I removed it today by drilling using a 3/16” drill bit and they came out quite easily. I have the deep storage bin removed and will just be needing to find the subwoofer box and top smaller storage bin. Just wondering what year TJ you have?Sorry for the late response as the other's said, from the top down.
If you happen to salvage the deep bin I may take it off your hands for the right price. Just let me know.
I have a 2004 but unfortunately don't have either of those. I spent the time fitting a kicker subwoofer into the enclosure that ended up dying on me after 3 months. Out of frustration and the need to eliminate anything electrical lower down in the tub (for spraying out) I yanked it out and threw it away. I attempted to modify the shallow tray but ended up screwing it up.....so now I just have a hollow console LOL.Thanks for the info, I removed it today by drilling using a 3/16” drill bit and they came out quite easily. I have the deep storage bin removed and will just be needing to find the subwoofer box and top smaller storage bin. Just wondering what year TJ you have?
Dang!! It’s taking me so long to find the sub enclosure! The smaller tray is more common but that sub box is like gold. Do you happen to have the stock subwoofer harness that goes under the console, past the shifter, up to the radio?I have a 2004 but unfortunately don't have either of those. I spent the time fitting a kicker subwoofer into the enclosure that ended up dying on me after 3 months. Out of frustration and the need to eliminate anything electrical lower down in the tub (for spraying out) I yanked it out and threw it away. I attempted to modify the shallow tray but ended up screwing it up.....so now I just have a hollow console LOL.
It's still in there but it' all intertwined with the parking brake wire so I just waterproofed it and left it in. Probably rather not take it out anyways in case I want to tap into those wires at some point. My interests change like the wind. I may be wanting to put a full blown system in it next year haha.Dang!! It’s taking me so long to find the sub enclosure! The smaller tray is more common but that sub box is like gold. Do you happen to have the stock subwoofer harness that goes under the console, past the shifter, up to the radio?
Thanks for the info, I appreciate any I can get because I have no idea about what “ga” stands for or anything sound related. I planned on following the popular guide that was posted on this forum. My plan is to add a kicker subwoofer and kicker amp as well. I don’t have the factory harness though because my Jeep wasn’t equipped with a subwoofer from the factory. How could I connect a kicker subwoofer to my head unit?If you are going to be adding a new sub amp (which you definitely should) then all there is is 2 wires back to the sub speaker. Use better wire (I think stock is 20 ga.) And get better speaker performance. Not trying to jack up your deal, just offer some info. Or run a self powered sub under drivers seat.
