Does anyone know the size of the purge valve line to tank connector?
John Scoggins
Houston, TX
Does anybody know the size of the connector that connects the steel line to the nylon line going from the purge valve to the fuel tank (just inside of the drivers side rear tire)? Mine is split and causing an EVAP code, I have attached a picture I found showing the connector in question circled in red.
Metal line is about 3/8" on mine and the plastic side is a little more, almost 7/16" O.D. and probably metric or 3/8" I.D. or something like that on mine. You could probably get 3/8" hose and make it work if you were careful.
Reactions: John Scoggins
