- Joined
- Feb 15, 2016
- Messages
- 2
I locked my 2000 Jeep Wrangler and when I went to open it the key wouldn't turn all the way to the unlock position, so I entered through the passenger side and tried to unlock the door from the inside, but the lock lever is stuck between lock and unlock, and I can't push it to the unlock position. I tried the WD-40 on the key suggestion, then I reached down in there with a hanger, not having a clue what I was doing but blindly hoping the hanger would responsibly guide itself to the proper position and do some magic, but that only made it worse. I believe I finished off whatever it was that was holding onto life by a thread because something came loose, and now the key turns to the unlock position, but the inside lock is still stuck between lock/unlock.
Before I call a locksmith I was hoping to find SOMETHING online about troubleshooting this issue, but everything I run into shows what to do while the door is open. I can't even get it open to start pulling the panel, etc. Has anyone had experience with this?
