A few months back I replaced the aftermarket alarm the PO had installed with a model that had a two-way remote and a mile + range. I re-used the door trigger wire that the PO had used, located under the dash to the left of the steering column.
Last week I started getting alerts that a door was open every time I set the alarm. Yesterday I had some time to kill and decided to figure out what's going on. I pulled both door switches and both operate properly. I snipped the trigger wire and hooked up my multimeter, no change whether the doors are open or closed.
For the hell of it, I thought, let's turn on the headlights and then open the door. I get the audible warning that I left my lights on, close the door and the warning goes away.
Before I go through the hassle of running new wires just for the alarm, is there simple explanation/fix that I should be looking at?
Thanks!
Thanks!
