That was/is a method for one man bleeding. Probably still at risk of sucking some air.Not a glass, but a container, why?
The 1976 CJ-5 service manual says to open bleed screw, push pedal down, let up slowly, close bleed screw.If someone does not close the bleeder valve before they release the brake pedal and it sucks back some fluid.
all that does is push fluid back and forth, without a checkvalve of some kind, you will never get a good bleed.That was/is a method for one man bleeding. Probably still at risk of sucking some air.
I've used speed bleeders on motorcycles and the TJ with no issues. It is simply a one way valve that lets the pressurized brake fluid out of the bleeder valve, but does let anything back in after the pressure is released.
There are only 2 issues to watch for: running the reservoir out while pumping the pedal, and loosening the valve too much where it may draw air back through the threads (1/4 turn is normally sufficient to get decent outflow).
For my '06 TJ Rubicon, I am also looking for the speed bleeder valves. I see that Dorman makes one for the front brakes (ref Dorman p/n 12701). I don't see anything for the rear disc brake bleeder valves. Does anyone have a source for valves for the rear disc brakes. According to my Parts Manual, the front bleeders are OEM p/n J3203313 and the rear bleeders are 05179732AA (post 10/2005) or J0920463 (pre 10/2005).
