Double cardan centering ball grease?
derekmac
NS, Canada
I'm replacing the u-joints in my front driveshaft, and I have the old grease cleaned out of the centering ball, and I'm wondering what type I should replace it with?
It's not fussy. Red Chrysler compatible grease like is available in tubes from Valvoline, Lucas Red 'n Tacky, etc. are all fine. I guess Lucas Red 'n Tacky would be in 1st place in terms of desirability but Valvoline or similar name-brand is of course a very good choice too.
Reactions: derekmac
How do you grease that area? Are you talking about the cv or whatever it is called in the front drive shaft?
You have to pull the skid plate and the front driveshaft in order to grease the front CV ball. I tried for a while to grease it without dropping the skid or the driveshaft, but it is damn near impossible. It isn't that hard to do it the right way. Just put a jack under the transmission, unbolt the skid plate, pull the driveshaft, grease the CV ball, and bolt everything back up. Use a bit of blue loctite on the 8 driveshaft bolts (although you could probably just take out the 4 bolts at the transfer case side).
Should only have to do this every 3000 or so miles. I would try to do it after every oil change. Should only take a half hour or so. Take greasing the CV ball pretty seriously. I had a CV ball go bad once due to a lack of grease. It is annoying but doable.
Reactions: inkedrose and Ted
