I know this has been gone over a bunch, and I have read most of the "HOW TO" on drive line vibration.
Here is what I got going;
Removed the 3.07 gears axles housings and all (front and rear) and replaced with Axles and housings from a jeep with 3.73 gears. Installed Eaton True trac in the rear Dana 35 and Ox locker in the Dana 30. Both Drive Shafts have been rebuilt with new spicer u joints along with the front axles bearings and u joints. It has all new upper and lower control arms (stock) non adjustable. The jeep has a 2 inch lift and im running brand new 31 inch tires falken wild peak tires.
During my numerous shake down drives, I get a vibration at about 65 mph, I checked the pinion angle of the rear end vs rear drive shaft about 7 degrees from 0, Removed the front drive shaft and no more vibration.
So as it sits now the rear pinion angle is right at about 7 degrees off 0 and the front drive shaft is out of the vehicle and I have NO vibration.
So for my questions;
When I removed the front drive shaft to install all new u joints and cardan joint, the "orientation" of the drive shaft got mixed up, I now do not know exactly how it came out of the vehicle, orientation wise. How do I know the correct orientation (so that its balanced) going back in. Is this even a problem, can you install it "out of phase" and cause vibration? Are the stock drive
shafts marked in some way to insure correct reinstallation? Or is installing new upper and lower adjustable control arms the only fix for the front drive shaft... also do I need a new balanced front drive shaft ie a tom woods or some aftermarket drive shaft?
IF the reinstallation is not the problem then could the front pinion angle be the problem I havent checked to see what the angle of the front diff vs the angle of the Drive shaft is at this point.
And last, the angle of the rear drive shaft vs the pinion is 7 degrees from 0 but does not seem to be causing a problem, is it something that NEEDs to be addressed, and I am guessing new adjustable control arms are the fix for that.
sorry this is so long but thanks for any help.
