I'm under my tj this morning and finally discover why the fan shroud on my jeep sits funny and my shifter seems too short. I just bought this 98 TJ and it has a "custom" long arm lift installed. Basically they took the existing trans/t-case crossmember/skid plate and dropped it to make room for the "subframe" that has the control arm mounting points. The trans mount installed currently looks to be aftermarket (based on what I'm seeing online) and thus smaller and so the whole engine/trans/tcase combo is at a weird angle. Unbolting the mount and raising the combo by ~2.5" seems to be the sweet spot for where all this stuff should be sitting stock (this is just an eyeball, i have nothing to confirm this, that's why I'm here). I want to make a spacer that goes in between the trans mount and the crossmember/skid plate but I want to make sure I'm not getting any of the driveshaft/pinon angles wrong. Can anyone provide the measurement for what the rear pinion angle and transfer case pinion flange should be?
I also have some concern about the rear driveshaft. The drive shaft slip yoke seems to be sticking out kind of far when I have the drivetrain lifted and the double cardan joint seems like its close to binding. I just want to make sure I'm not gonna screw this stuff up
Pictures for reference
gap between top of trans and trans tunnel as it currently sits
t-case pinion flange as it sits at the funky angle
current rear driveshaft slip yoke
current driveshaft angle
proposed "new" gap between trans and trans tunnel
"new" 2.5" gap between trans mount and crossmember
how the cardan joint would sit
how the slip yoke would sit
the "new" angle of the transfer case pinion flange
"new" driveshaft angle
