Reading up on the description of https://www.amazon.ca/dp/B000MMFJH0/?tag=tjforum-20
I think it should be a pretty minimal way to run a dual battery. I don't think it's optimal, but from what I could tell, it should be fine. I still recommend a good charge controller, because batteries ultimately end up costing you a lot and add on the chance you get for a bad battery spoiling your food and/or recovery. I just worry a little about manual and my forgetfulness too. Having a switch like that on hand, would be a good backup eventually as well, but I still lean toward having a cheap Solar charge controller for my backup and can often be found much cheaper, though it's more complicated than the switch that was recommended above so more likely to fail than.
