Just got a few questions about running a 12 volt inverter off my second (deep cycle) battery. I don't see many of you in the US using inverters or dual battery set ups but they're very common here in aus for overlanding or long distance remote trips. When I bought my TJ, a previous owner had already set up the dual battery system, with a double ciga plug (cigarette lighter style accessory outlet) mounted on the back of the centre console that he said is running straight off the second battery. I use one of these plugs to run my small electrothermic fridge with no problems.
So my first question is; I've seen very small inverters (150 to 200 watt) that are designed to plug into a cigarette lighter, but the bigger ones (I'm looking at running a roughly 800 watt inverter) come with leads that are meant to be attached directly to the battery terminals. If I was to assume that the double ciga plug outlet goes straight to the second battery, could I just solder a ciga plug onto the end of the leads of a bigger inverter and plug into that accessory socket?
Second question is, how can I determine how large of an inverter I can safely run?
Also, the smaller 150 watt inverter doesn't have a point for chassis earthing but the bigger ones do, why's that? And how would I earth a larger one to the chassis anyway?
Cheers
Cheers
