I have the same size tire, it is most likely a load range E. as in it will meet the load cap of an f350 or something of that sort, I keep mine at 30psi since stock it came with 4 or 6 ply tires or load range C. since the 285 TIRE size is a much heavier duty tire, it can easily be ran at a much lower pressure since it is only carrying a fraction of its designated capacity. if you do alot highway driving then 40psi would be ample and give you a slight gain in MPG. BUT AS YOU said, I'll take comfort over MPG.
