Waiting on more bleeding until my Canadian reservoir arrives. It shipped but who knows when it'll get here
Meanwhile I worked on finalizing some wiring.
Put a temporary switch in the passenger footwell. Waiting to take the center console apart until my custom Carling switch arrives.
One trigger of the relay will be the cigarette light... basically ignition on...and the second will be the "bypass" switch on the dash that I will engage when crawling.
Went for an hour ride on Forest Service roads. 4 low through two big washouts. Found a wrecked Mazda Tribute down an embankment and got asbestos testing done on an abandoned trailer...all things Friends of Fall Creek Watershed...a non-profit we formed to clean up our public lands...works on... volunteer cleanups every Sunday.
The brakes really grab quickly. I had to pull the rod down slightly to engage the pedal button. Thinking I might move the button up an inch to increase the throw...right now you have all the brakes inside of 2 inches of pedal movement.
Best way to describe it is vacuum assisted brakes are on a logarithmic curve...comes on slow and ramps up the more you mash the pedal.
IBooster is very linear. You get used to it...but it's almost scary at first.
Going to look into if I can engage the CAN bus programming. Apparently there are different "modes" you can set. And I'd love a electronic brake for winching.
-Mac
