But I wanna play in the sandbox with you guys....
Right now the only thing in my sandbox are cat turds.
That's fantastic! After parts, machine shop prices, and engine labor you would have been in it for not much less had you done it on your own. Plus you basically got taxes and shipping for free just by contacting them directly. Nice work! Thanks for the inside scoop on the direct contact.Well I pulled the trigger and ordered and engine. Called ATK directly and they were offering 10% off and then $50 off because I waited a few days after contacting them... lol.
It was $1841 for the engine, $95 shipping and $130 tax so I got out the door for $2066 which I thought wasn't too bad after I did a ton of research. It was cheaper to go right to ATK vs Jegs or Advanced Auto, etc...
What all do you have to transfer over from your old motor?
Here's the list of mopar part #s if needed ‘04 4.0
Front Cover Gasket: 53020487
Front Cover Seal: 33004681
Timing Gear Set: 53020443
Timing Chain Guide: 33003446
Timing Gear Set: 53010557AA
Timing Chain: 53020444
I know it's an old thread. Which ATK did you purchase? I am in the same situation.
ok, noob swap question... so, my current 4.0 has the coil pack... how do you know if the reman uses a distributor set-up or the coil pack?
Thank you for the quick reply! I greatly appreciate the help!I simply called ATK and told them my Jeep info and vin number and they sent the engine I needed which uses coil packs. Don't remember the details and the Jeep has long been sold
The VIN number is what they are going to work off of. Good luck!
