Those are engine mounts. I’m aware— thank you. I’m asking if anyone has experienced broken bolts in the engine slots that HOLD your engine upBrown Dog makes a bracket kit exactly for this reason:
https://browndogindustries.com/S2883PHW-Wrangler-I6-Engine-Super-Brackets-Header.aspx
Or helicoil worse case scenario ?Looks like a drill and tap it out situation.
Yes, I’ve used heli for a couple application with good results. I’ve also welded on a broken bolt and gotten them out that way with some good heat and kroil.Or helicoil worse case scenario ?
HAHHAALord girl , just when I thought no Canadian had more problems than Justin Bieber...you come up with another one .
Before you go the drill and tap route , go ahead and soak them in a good penetrant like Kroil , maybe that and a left handed drill bit and ease out will break the free , they aren't under tension likely .
Good luck ....again. At least you aren't afraid to go for it .
The women on this forum are usually amazing .
You officially have the most problematic TJ that’s ever graced this forum, I must say. Kudos to you for trying to sort it all out.
im just thankful I can laugh about it at this point and get some help from some of you fine men with experience from this forum. This forum has helped since I joined. I respect the men who show knowledge 100%.Lord girl , just when I thought no Canadian had more problems than Justin Bieber...you come up with another one .
My girl said the only way she’ll marry me is if we put the Jeep in her name....then I’ll never be able to leaveHere is my overall view...
Life is hard at times .
We are all here on this spinning ball of mud to help each other.
I know my antics are probably getting old , but this is a fun place to cut up , have a laugh, learn and share. Plus my wife can't smack me. Boy she's tired of my craziness after 26 years .
There goes my TJ forum life .....And a friendly reminder, if anyone on here doesn’t like one another, just press the ignore button. If you do that, you’ll never see a single thing from them ever again, nor will they see a single thing from you. It works exactly like the block function on Facebook.
Thank goodness for that. Have so many Joe Schmos taking offence to such small things and bringing it up and trying to create drama. No thanks. Just here for technical support and potentially some laughs lolAnd a friendly reminder, if anyone on here doesn’t like one another, just press the ignore button. If you do that, you’ll never see a single thing from them ever again, nor will they see a single thing from you. It works exactly like the block function on Facebook.
Thank goodness for that. Have so many Joe Schmos taking offence to such small things and bringing it up and trying to create drama. No thanks. Just here for technical help and potentially some laughs lol
