My TJ recently began stalling after deceleration on a recent trip. It happens mostly after going highway speeds. After slowing down for exits or stoplights etc. Has anybody had a similar issue?
This happened just before I headed out for the hidden falls trip@freedom_in_4low, no my speedmeter doesn’t work either. It’s kind of annoying. Would like help with figuring that out too. Me and @TJ Starting were working on my transfer case and when I put the wire back in above the transfer case; idk what happened but ever after I don’t have speedo readout. Something to do with the speedo gear or something. Idk. Hasn’t worked since.
He doesnt have a speedo healer, only thing that was messed with is he changed to oring since whoever had installed it last had pinched the oring and it was leaking. I'm pretty sure it was clocked right on reinstallation but may need to be double checked.Is your speedometer functioning? I had this happen once when I went for a test drive without programming my speedo healer.
