WTB: Factory Sirius kit
Got4wd
Reno
Looking for the Sirius add on kit for 03-06 wrangler or if you went to a new head unit and not using the factory stuff i would be interested in purchasing.
I’ve been doing a bit of research on this. You can buy Sirius antennas all the live long day, the plug is universal. But you’re held up by the integration module between the radio and the antenna.
It seems that any of the Chrysler vehicles with the oval radio used
the same module. You might be able to find one at a junkyard and also snag the two plugs that go between the radio and the module, then splice wires in at your preferred length. If not, the FSM shows it would be really easy to create.
Part # is Mopar 05064074AC. Here’s the link to a module on eBay. You could probably find one in a JY for cheaper tho.
https://rover.ebay.com/rover/0/0/99?loc=https://www.ebay.com/p/28023752352
I think I have the Sat receiver I pulled out of my '06 and the antenna is still attached to the roll bar, if I can find it in my storage locker you can have it
There are 2 part numbers to make up the kit. Figured there is enough people that want a upgraded head unit etc
Sorry, just got back from commiefornia retrieving the rest of my crap.
found the receiver age here, just need to figure out how to get the antenna out of the jeep with the top still on
No worries. I appreciate it.
The antenna is on top of the left side roll bar above the door. I believe the wiring is just under the padding down to the floor, then under the door opening and up to the module under the steering wheel.
