Laid the Wrangler (2002 I6 auto) up for the winter, battery disconnected.
5 months later re- connected battery and started as usual.
Left it for 2 weeks and the battery was flat, jump start failed.
Fitted new battery, it now cranks well but won't start.
Used the built in diagnostics pulled fault P0320 Crankshaft position sensor.
But the actual meaning of the code, as I understand it, is that the E.C.M. is not receiving a signal from the C.P.S. so could it be a blown fuse, faulty wiring or something else?
Before skinning my knuckles and teaching the neighbours kids a new, blue vocabulary, is there a way to test the CPS in situ with a multi meter?
