I see lots of recommendations for Dewalt and Evolution "cold" saws. They aren't really cold saws but carbide tooth saw blades saws that run a lower arbor speed to make them work with the carbide tooth blades. I can tell immediately if someone knows anything about the saw technology if they recommend either of them since they are pretty much bottom of the barrel compared to the Makita. I've been using the Makita saw for at least 12 years and I've gone through at least 30 blades. My only complaint is I wish it was a 14" saw at times but that is only a few times a year. It is also something I use almost daily.
I used the Dewalt when I broke my Makita. It was a loaner, it was nearly new and I would buy a Makita before I would use a free Dewalt for more than a couple of cuts.
My helper's brother is a cheap ass and bought the Evolution. Helper reports the same as me, he would buy a Makita (and did) before taking a free Evolution long term.
One thing that I don't see mentioned often is the accuracy and precision of this type cold saw or at least the Makita. With an abrasive saw, you can't take a smidge off the end of a piece. The shortest cut you can make is the width of the blade plus some so the blade doesn't just walk out of the cut and off to the side.
With the Makita, you can cut .010 off the end of something that fits in the vise.
The best deal going on blades are by Freud. Their Demon blades for steel are the best so far. Especially the best value per cut. To date they are the fastest cutting and are the cheapest price. Pretty hard to beat. Not knowing if this is an anomaly, I snagged 6 of them to put on the shelf because I still don't believe a 50 dollar blade works this well and they may figure that out and raise the price.
You can't get by with one saw but if you have to pick one, get a cut off saw.
