2004 TJ.
I installed a LED into the LR socket, but it didn't fit correctly. Removed it and install the old bulb.
The next morning I noticed I had no turn signals. Turn signal fuse was ok. While searching I found the #27 MFSW blown. I replaced it, but the fuse popped right away. But I noticed a fast clicking noise that sounded like the turn signal relay. Bought more fuses and a relay. The new relay doesn't pop the fuse, but it hyperflashes the turn signals. My front LEDs are flashing.
Then I realized I have no bake lights. I replaced the multifunction switch. No change.
It's hyperflashing with the ignition off. There shouldn't be any power going to the turn signals. I removed the ignition switch connector, but it still gets power.
Other related threads all got fixed with a new LED relay or by replacing the switch.
I'm wonder what I FUBAR'd
