Hi All - I started to swap my front turn signals, brake lights, and side markers to LEDs and got all kinds of weird things going on. After some reading here, I tried the EP26 relay and EP27 relay and neither worked "correctly". At this point, I decided to swap everything back, including the original relay to get back to ground zero and nothing works ... no turn signals or flashers. My last attempt was to replace the relay with the LM470, leaving the non-LED lamps. Well, in the garage, it looked successful. Flashers and turn signals worked. Side markers flashed with the front turn signals. I put the steering covers back on and went for a drive and now I have nothing again. The fuse looks good and I swapped with the spare.
My thought at this point is either the relay is loose or there's some other loose connection somewhere. Any common failure points or recommendations on how to troubleshoot from here?
Thanks!
Thanks!
