I see many posts about what to do for turn signals once the factory fenders are removed, and it seems that the options are somewhat limited due to space limitations and/or a suitable mounting position.
While searching for some additional turn signal illumination for my Harley, I came across these and couldn't resist checking them out for only $10.99...
https://www.amazon.com/dp/B0BPM33JMQ/?tag=wranglerorg-20
They arrived yesterday and I'm actually impressed by the build quality, as well as the amount of light they produce.
They are available in chrome or black.
If the housing doesn't work for you, there is a small set screw on the side that will allow you to disassemble the light and then you get this:
Which I'm sure is small enough that many could figure out a way to make it fit into the edge of the fender.
