VIKE
Sure. There’s really nothing to it. These Jeeps are made for flat towing. Just follow the steps very carefully.
First & most important is your hitch set up. Be sure that you have purchased good equipment. I use a Blue Ox tow bar & it’s great. If you are using the recovery lugs on your bumper just be sure that it is adequate for the job. I bought a Smittybilt XRC bumper for this purpose. I’m sure there are other bumpers that would work well too. The recovery lugs go through the bumper & are welded on both sides.
Here are the steps for hitching up:
NO! In the owner’s manual under “Recreational Towing” it stated that automatic transmissions must be in park & manual transmissions must be in a gear, 2nd or 3rd is suggested. I don’t know the reason for this, but it’s what I have always done & it works great.
What you do have to do is make sure that the transfer case is in neutral. I test this by putting it in gear with the transfer case in neutral. I hitch up, put the transmission in gear & let out on the clutch like I’m trying to drive the jeep either in forward or reverse. Of course, the RPMs will rev up & the Jeep won’t move. If you do this check you will know that your transfer case is in neutral & everything is good to go.
The final, but very important step is to be sure that your steering us UNLOCKED. Failing to do this will cause excessive tire wear & damage to steering components & tires. To unlock the steering simply turn the key back one click from the run position & leave it there. You will not be able to remove the key & this is perfectly OK. When the motorhome is parked we have an extra set of Jeep keys attached to the steering wheel with a Velcro strap so that we don’t forget this step.
This is great information Mudflat! I’m heading to a trailer outfit now to have him check my bumper. I too have the XRC bumper added onto the frame, so hopefully that’s all I need. They also sell the Blue Ox system i believe , so will have to ask about that as well as breaking system, and lighting.thanks again!
