We considered a clamping table, may if we move to a larger shop.Sounds like you need some JLT Clamps equipment.
When you do. Click on the link and give us a call. Ask for me.We considered a clamping table, may if we move to a larger shop.
Man that is awesome- you know what I’m into. Those are important machines.When you do. Click on the link and give us a call. Ask for me.
All made in the USA up here in beautiful Poughkeepsie, NY.Man that is awesome- you know what I’m into. Those are important machines.
How much run time on this? I’m a little surprised how much the tires are showing vs the shocks (but I have no reason for that other than expecting shocks to heat up a bit vs the gas tank).
30 minutes, highway speeds, ambient temp, 90 degrees outHow much run time on this? I’m a little surprised how much the tires are showing vs the shocks (but I have no reason for that other than expecting shocks to heat up a bit vs the gas tank).
That’s great, thank you! I don’t remember on your rig, do you have carpet inside still?30 minutes, highway speeds, ambient temp, 90 degrees out
Yes, i have all the factory carpet and some sound deadener under parts , but not up on my tunnelThat’s great, thank you! I don’t remember on your rig, do you have carpet inside still?
I ask because I put in a tuffy and it gets really hot above the tranny tunnel too. It may answer which end I need to focus on.
Not dead sure, will play with it and see. I should be able to watch it change as i move the camera and get an idea.Cool pics! Is the temperature shown for just the area inside the circle? By any chance is there a color scale chart for the color/temp ranges?
Temperature displayed is for the area just inside the circle.Cool pics! Is the temperature shown for just the area inside the circle? By any chance is there a color scale chart for the color/temp ranges?
Lordy-Figured that would drive yall wild.mmm, I'm diggin the upskirt shot of that hot rear end
