Quick question… racking my brain tracking this down.
My floor vents and dash vents are always on. I can switch it between the defrost and dash vents but the floor is always on.
I can feel the valve in the bottom center moving with my hand but when I switch between floor and dash it moves but then slowly creeps back to its original position…
When it does move there’s no change in air speed for the dash or floor …
I’m not sure which valve actually controls the floor vents…
I’ve checked for vac leaks and I haven’t found a smoking gun… when the jeep is off when I pull a vac line it’ll make the woosh sound like it is still holding a vac though so I’m not sure if it actually is a vac leak…
Anyone else have some tips on where to look for this?
