Hey everyone!
The other day when I was installing my after market radio, I came across a random Blue with Pink (maybe red) Tracer wire, it wasn’t connected to anything, I figured it might’ve been a leftover Add-on from the PO so I started to pull it out thinking it’ll be tapped or spliced into something unimportant but then I traced it back to a fuse holder thing? (Sorry for the terminology) and where it led to seemed too professionally done, the electrical tape was either from factory or the PO did a good job on it. which didn't make sense since the wire was not properly secured anywhere.
This is the wire as I found it behind my radio...
I traced it back and it leads into this fuse holder here, I haven't had time to be able to see if there is voltage running through it, the tape looks (to me) from factory but I found it odd that the wire was not secured. the fuse holder is right above my clutch pedal. Anyone have an idea if this should be connected to anything? Everything, that I know of, works unless its related to the hardtop, PO at some point switched to soft top.
Here is a picture of the wire as a whole. I am ok with cutting it if no one thinks its OEM/Factory, I just wanted to make sure before I regretted doing so. The other end of the wire is a thicker gauge wire that leads behind a connecter off to the left of where the fuse holder is. I'm hoping I can upload photos later today.
Anyone have any ideas on what to do?
