CreepinDeth
Spray end result depends on the
1. texture of the product,
2. volume of the spray nozzle
3. Skill level of applicator
4. Surface area cleanliness
If someone uses basic home user grade clear coat which isnt for an undercarriage, it wont look or last like a thick sealcoat
I just rubber seal coated my frame also, and it varied based on the output volume fluctuation of 2 different products from the same manufacturer
The rear I used Rustoleum Undercoating
The front I used Pro-Grade Rustoleum Undercoating
I can 100% confirm that the Pro-Grade had a more balanced volume and looked alot smoother. I used a 3rd Rubber undercoating product years ago on my F150 that sprayed such a heavy volume that the end result was goobered up slop everywhere. Trial and error
