Kenneth G Zinis TJ Enthusiast Joined Nov 6, 2018 Messages 682 Location Bethlehem, PA Feb 20, 2020 #1 Did Jeep offer TJ front bash plates, aftermarket or has anyone made their own? Similar to Raptors, Tacomas, etc.
Goatman TJ Expert Supporting Member Joined Apr 23, 2019 Messages 5,041 Location Upstate NY Feb 20, 2020 #2 I don't think so. I have read on this forum about a lower radiator skid plate, but the consensus was that it wasn't really needed.(IIRC) Reactions: JMT
JMT Just another auto... Supporting Member Ride of the Month Winner Joined Feb 27, 2017 Messages 22,574 Location 🌎 Feb 20, 2020 #3 Steering box skid, engine skid, TCase skid, gas tank skid, and mini CA skids
Steel City 06 TJ Expert Supporting Member Joined Mar 12, 2019 Messages 4,516 Location Pittsburgh, PA Feb 20, 2020 #4 More commonly people simply build up the components on the front axle. Examples: Nodular iron differential covers Half differential cover armor Differential ramps Heavy duty tie rods and drag links (ZJ steering, Savvy tie rod, etc.) Axle tube sleeves Mini skid plates for LCA mounts Beefier knuckles Stronger steering boxes Steering box skid plates Large angled bumpers Radiator skids Engine skids Axle trusses Stronger pitman arms Stronger control arms and joints Stronger driveshafts Full replacement Dana 44 or Dana 60 front axles Big brake kits High steer kits Stronger trackbars Crossover or inverted T steering Some of these features are of arguable benefit. Some are more common than others and some will increase impact resistance more than others.
tworley Ignored :( Supporting Member Ride of the Month Winner Joined May 23, 2018 Messages 8,354 Location Arvada, CO Feb 20, 2020 #5 What exactly is a bash plate? I am picturing something like a bull bar...
Steel City 06 TJ Expert Supporting Member Joined Mar 12, 2019 Messages 4,516 Location Pittsburgh, PA Feb 20, 2020 #6 tworley said: What exactly is a bash plate? I am picturing something like a bull bar... Click to expand... A skid plate that is angled like a ramp. Usually installed on vehicles with IFS to protect everything between the LCAs, especially the front differential Since the entire axle moves on a TJ, there’s no good place to bolt them on. With double wishbone IFS, you simply bolt them to the frame by the front LCA mounts and to the bumper or crossmember.
tworley Ignored :( Supporting Member Ride of the Month Winner Joined May 23, 2018 Messages 8,354 Location Arvada, CO Feb 20, 2020 #7 A good bumper than can be used to slide/glide over an obstacle would be the motobilt competition front bumper. Otherwise I would stick to a stronger steering system, steering box skid, oil pan skid, control arms skids, and stronger diff cover. Reactions: Steel City 06
Fouledplugs TJ Guru Supporting Member Joined Jun 19, 2017 Messages 7,049 Location Alabama/North Carolina Feb 20, 2020 #8 Kenneth G Zinis said: Did Jeep offer TJ front bash plates, aftermarket or has anyone made their own? Similar to Raptors, Tacomas, etc. Click to expand... What you're seeing is a skid solution for their IFS axle center sections. No need for that on a Wrangler which utilizes a straight axle in the front. Reactions: EJD
