I noticed my front calipers where dragging so i decided to replace the calipers, rotors, pads and the soft lines from the frame to the caliper. Originally I thought my calipers were bad which is why I replaced everything but there must be something else wrong. I've bled the brakes multiple times even flushed the old fluid but my front calipers are still dragging. What else should I be looking at that could cause the sticking? I pump bled and gravity bled the brakes numerous times and still no improvement. Could it be the proportioning valve or master cylinder or booster? Also, when i bleed the brakes the peddle clearly gets stiffer but once I start the jeep, peddle goes soft.
