So I have a rounded head on the yoke at the front of the transfer case. All the components I find list 97-02, so what gives from the 97-02 to the 03-06? Pic below shows problem area, specifically the double cardigan to the yoke are the parts I need.
I dont believe there is a difference. A std non Rubicon shaft uses 1310 joints at the yoke. The bolts should be the same. Someone correct me if I'm wrong.
Well I was having a brain fart at the time. Got the shaft out with only little damage to the yoke. Already have a replacement coming so I’m set. Thanks!
