Front driveshaft rebuild kit
You need to inspect your front driveshaft and determine if any of this information applies to your Jeeps front.
Jeep CV Driveshaft Centering Yoke 1310 Series Rebuild Kit with 3 U-Joints
Use on OEM NON Greaseable 1310 series CV Driveshaft to repair or rebuild Double Cardan Joint
  • Centering Yoke Fits 1310 Series Universal Joint
    • Dimension between locating tabs on centering yoke is (3.219 inches) 3 7/32 inches
    • Designed to fit (1.062 inches) 1 1/16 inch U-Joint Bearing cap
Fits Jeep Models with OEM NON Greaseable 1310 series CV Driveshaft Front/Rear
  • DOES NOT fit 2003 to 2006 Jeep TJ RUBICON Models with 1330 series front driveshaft
  • DOES NOT fit aftermarket 1310 CV Driveshaft with FLAT FLANGE at TRANSFER CASE
  • DOES NOT fit OEM or aftermarket 1310 CV Driveshafts originally built with a Greaseable CV Centering yoke
