Hi all I own an '03 TJ I6 4.0L 6-speed Manual!
I've stalked this forum for some time and I officially need help with an issue I'm facing. The front passenger side sags more. And before you tell me to change the coils, I just did two weeks ago to these. This car was involved in an accident, (not major). Took it to a shop, the only thing that they noticed was the lower control arm bracket on the diff was bent on the passenger side. They changed both driver and passenger side and aligned it. The jeep rides MUCH smoother than it did before, but the front still sags. I've measured along the chassis on the mounting points and they look the same on every point. I also measured the size of the spacers for the body lift and those also look fine. What I did notice is that this issue is only isolated to the front passenger near the fender area (where the accident occurred) which is most likely why my hood is also not aligned. This was the only other resource I could find online.
Front view of visible passenger lean:
Driver side bushing:
Passenger side bushing:
