I replaced the back shocks. While working on the front ones, I stripped the upper nut, I noticed the shock rotates with me wrenching on the upper bolt. How do you suggest I proceed with it?
I am using channel locks to remove the upper bolt while holding the shock from rotating, I’m not getting anywhere. I am assuming cutting the upper is the answer here, right?
Would a sawzall work on it?
How would you remove the other side Without causing as much headache? I used a 16mm wrench to get this side off but ended up stripping the nut.
Thanks
Thanks
