It's hard to see what's going on with the driver's side track bar mounting bracket, the camera exposure has washed out that area. It might just be an aftermarket bracket without a drop. Notice the brightly lit lower area is properly exposed, the area we need to see is not and it's simply because the camera is pointed more at the brighter ground level area.
Can you take and post another photo with the camera pointed directly at that upper area so it calculates its exposure for the darker area the Pitman arm and track bar mounting bracket are located in? Turning the flash on while doing that would produce a much easier to interpret photo.
