Fuel Leak While Pumping
Username
Lifetime Supporting Member
Louisiana
I have a slight fuel leak from this crack only while pumping, and also a PO456 code . Is this yellow piece able to be replaced, or is it integral to the tank?
My other question has anyone tried to use something like this to seal plastic? Or does someone have another product they've tried? I'm thinking I'll sand the plastic some, clean it up and try that plasticweld.
I've never seen a replacement for that piece. I am guessing you could seal that with some plastic epoxy weld.
Reactions: Cooper Smith
The JB plastic weld should honestly do fine. Just make sure it is pretty clean before epoxy
