Kraken72 Bolt Breaker Supporting Member Joined Jan 4, 2022 Messages 192 Location Louisiana May 29, 2022 #1 Hello so having some fuel leak issues. What brand fuel pressure regulator is everyone using for a 97-02 TJ?
97JadeTJ TJ Enthusiast Supporting Member Joined Aug 14, 2020 Messages 776 Location Hot Springs, AR May 29, 2022 #2 This is the one I used with no trouble other than I didn’t tighten down the locking ring well enough… this is the pump, sending unit, pressure regulator all in one… https://www.amazon.com/dp/B07MYW9PY6/?tag=wranglerorg-20 Reactions: Kraken72
P pagrey TJ Guru Supporting Member Joined Apr 10, 2018 Messages 7,725 Location Los Angeles, CA, USA May 29, 2022 #3 Where is fuel leaking? That's not a normal thing so it would be interesting to hear why you suspect the regulator.
