If you follow my build thread, you may recall that during a wheelin' trip last weekend I began having trouble starting the rig. Long story short, the problem is most likely the pressure regulator in the pump not holding pressure, and leaking down when not running. If I cycle the key a few times, it fires right up. It could also be a leaking fuel injector, but I think that is highly unlikely.
The stock pump in my '04 puts out 49 psi, while the Hemi requires 59. In '05 Jeep went to a 59 psi pump, but the pump is different and does not fit the '04 style tank as I understand.
When I built and installed the Hemi in 2018, I picked up a fuel pump (among many other parts for that matter) from Red Rock Off Road. This pump puts out 59 psi and fits the '04 style tank, but does not have a built in filter. Guess which one it is:
Yeah, the cheap looking plastic piece of crap on the right. It worked, but I was disappointed with the apparent quality of the thing from the start. Well, now I think that has come back to bight me.
I pulled pictures of the box and all the documentation I have on the pump, but there is nothing that helps identify it. I have an e-mail and call into Jim Beebe over at Red Rock to get the info, but have not had a response.
All that as background to my question: Does anyone know of an in tank, no return fuel pump which will fit an '04 tank, and puts out 59 psi?
Thanks in advance.
Thanks in advance.
