When I shut off my TJ and get out I have a strong odor of gas, no jokes here. I do not notice it while the engine is running, only with it shut off. Where do I start looking at?
Thanks
Thanks
Has your mpg taken a hit since the strong fuel aroma started?
Any evidence of it leaking onto the ground? Do you smell it when you walk out to the TJ in the morning when it's cold or does it only happen after the engine has warmed up?
Any issues with fueling? Pump shuts off normally...no spitting?
How do your soft fuel lines look? I've got my tank out now and am going to replace the lines because they're probably originals and checked and cracked.
Any rust on the hard lines?
I originally thought I had a fuel issue in my Jeep until I realized it was my chainsaw burping gas. I leave it empty now and have MSR fuel bottles titan strapped to the tire carrier.
My tank is out to repair rust and pressure regulator/check valve.
-Mac
My initial suspicion for a gasoline aroma when it's not leaking is the engine is running too rich due to a bad upstream O2 sensor. They don't always or even often generate a bad O2 CEL code.
If you decide to replace the upstream O2 sensor make sure to only install NTK, NGK, or Mopar. Avoid store brands and especially avoid Bosch which doesn't work well in our Wranglers.Thanks for the input. I will crawl under it this week and see if I can see a leak. If not I may just by the O2 sensor and replace it. I know there are several, should I replace them all? If not which one are you suggesting I replace?
Your TJ only has one upstream O2 sensor, it's mounted on the exhaust header adjacent the engine. The downstream O2 sensor is screwed into the catalytic converter and it does not need to be replaced, it only monitors the cat and has no effect on the engine or its fuel/air ratio which is solely controlled by the upstream O2 sensor.
then don't shut it off!When I shut off my TJ and get out I have a strong odor of gas
Thanks
There are two vent hoses on top of the tank hopefully the fittings aren't broken. Bosch pump
Thanks for the input. I have watched a couple of videos on how it goes. As long as all goes well, it doesnt look like that bad of a project.
