Remove your instrument cluster and radio. Clean the ground wire behind it. Follow that wire and clean it’s contact also. See pictures. View attachment 149670View attachment 149671
IF I were to guess why that CCD bus connector is connected to the factory radio would probably be for the lighting dimmer function of the radio.
YES.... All of those black wires with the star washer are grounds and should be connected to that screw.... I have three wires connected to ground near the speaker on my 01. .
My 01 TJ did not come with the factory radio; the SONY radio wiring was connected so poorly and the factory harness was butchered so badly that I had to remove the radio, radio pigtail and part of the factory harness to trace out wiring to figure out what the previous owner had done.
But yours does not have this ccd bus wires for the radio. Not even in 98 Had those radio ccd bus wires. I swear this was the first tj on the line in 96.
I understand the early years of TJs had wiring that was in its infancy in the development of the TJ and as the years went on the wiring changed.
In your Post 6 picture the Radio CCD wiring would go to a radio module on terminals 1 & 2 (IF EQUIPPED).
I found a detailed explanation of the Function of the CCD "Collision Control Data" bus.
