I just picked up my first TJ and there is a lot of play in the steering even before the gearbox is engaged, that is the play I want to fix. Admittedly I will be doing other front end fixes in the near future but I don’t think any of that would cause the play I’m experiencing.
I took it to a mechanic who just changed the steering gearbox, he said it was leaking but the play is still present.
So now there is a brand new gearbox and I have examined where the play is by following the shaft all the way to the top of the gearbox, it’s moving right at the connection but takes a few inches of steering movement to actually start to move petmin arm.
The mechanic is saying it’s everything after the petmin arm, U joints, tires, ball joints, etc. but my research on here makes me think he is looking in all the wrong places.
I just had my wife move the steering wheel with the Jeep off, and she was able to rotate the steering probably 3-4” to each side from center before it was “hard” - since the power steering is off she was right in the play area before the wheels engage.
The shaft has immediate response to the wheel turning, all the way along the shaft but right below where the bolt that holds it onto the steering box I can see it doesn’t move the ring above the box or the petmin arm, I’m assuming this play is in the box itself.
I’ll admit I am new to TJ and also new to mechanics but I’m a fairly logical guy and to me it doesn’t even seem to be the shaft, it looks like it’s the gears which I just replaced!! Now I’m going to try to adjust the gear box today but my concern is that my steering doesn’t return to center already, but I’m assuming this could be bad u-joints, ball joints, control arms causeing that but I don’t know.
Can you guys help me understand if it’s feasible that the lower shaft may not be engaging and therefore needs replaced? I’m wondering if the connection to the gearbox may be able to cause play? Can the lower shaft connection at the bottom be stripped or something?
It does appear someone put spacers on the springs, I’m guessing 1.25” based on my measurements and I’m running 31’s - I don’t really know much if anything else was done to accommodate for the lift, I just picked this Jeep up and don’t know much about it.
I have looked at a ton of articles on here and I expected the gear box to fix it. Any chance or way to test if it’s a bad replacement gearbox?? Need some help here!
