I have been wanting to learn how to actually weld for a while now instead of just tacking things together while a friend perfects it and such.
I've seen that it is a paramount skill when working on the jeep most of the time.
What would you all recommend for getting started?
Buy a 220v Mig with decent amperage. 180 min.
Buy a way more expensive auto darkening hood and extra lens covers than you think you need. The key to good welding is knowing what to look for and being able to see it. If you don't spend around 175-200 on a good hood, don't even buy a welder.
Do NOT be tempted and fall into the flux core trap. Once you learn how to weld with that crap, it ruins you with bad habits for good welding. Learn how to MIG first and then use the flux core as a solution to a problem when you are field welding off of a generator in the wind on dirty metal and just know that your welds will look like that even if you do them under good conditions.
Buy two sets of good Mig gloves, one for using with the grinder and the other set you
only weld with.
Buy a good tip cleaner and nozzle spray and use both religiously.
If you are running .035 wire, use a contact tip for .040. If you are running .030, use a .035. Much less frustration when you keep burning the electrode back to the tip and melting it in place.
Do NOT ever buy into the philosophy of "my welds may look like crap but they are strong". If you learn good puddle manipulation, you will automatically produce a good looking weld. If you make a bad looking weld, it is because you never learned what to look for and how to adjust your machine for the conditions you are welding under. I will adjust my Miller 212 auto set at least 4 different times just doing a shock outboard job. The same speed and rate for a horizontal weld along the top of the frame doesn't work very well for under the frame tying in the bottom edge to the frame.
Do NOT buy into the philosophy of needing a particular tip movement to learn to weld. If you teach yourself to pull with a 45° electrode angle and 45°to the material on a fillet weld without tip movement just learning to move the gun and watching the fill rate, the small bit of tip movement will come naturally as your skills progress.
#1 Tip? learn to listen to the weld. If it starts sounding angry like water dropped into hot grease, you are staying in the puddle too long. Either speed up the travel rate, turn down the amperage, or turn down the wire speed. You are looking for a nice even buzz and that will give nice weld appearance, reduce spatter, and generally be a good weld.
