It's getting worse, I have checked the res level and at the mark and the fluid is clear. Any ideas?
Did you ever get to the bottom of this? My LJ has an automatic trans and I've been having a very similar issue.Random semi-related question: anyone else have an automatic transmission that shifts hard into reverse? Whether it's level ground, an incline, whatever, if I'm not pulling the shifter all the way through to D, its a hard clunk and anything but smooth to shift into R. Not really grinding but it sure doesn't feel right either.
It's worst in the AM or after it's been sitting for a while. If I go run and errand, get out and get back in the car, just as smooth as shifting to D. Conversely, if I leave it overnight, start up and go straight to drive, it's more or less smooth shifting.
Time for a new transmission
As it turned out, this was the correct answer lol.
Apparently a PO had used the Jeep as a submarine and water had made its way in to the case at some point. Frankly that's just trivia as far as I am concerned since the transmission was OE to the LJ with no apparent rebuilds, and it's right at 200k, so kinda time for it to be ready for attention anyway.
