808jeeper Member Joined Apr 22, 2020 Messages 69 Location Oahu Apr 6, 2021 #1 Howsit I have a 02 Jeep tj 2.5 5speed I have a grinding noise that’s loudest when doing 45mph it happens in gear if I let off the throttle and in neutral.
OP 808jeeper Member Joined Apr 22, 2020 Messages 69 Location Oahu Apr 6, 2021 #2 it isn’t constant but pretty often. Could it be throw out bearing? Reactions: Tree killer
AndyG Because some other guys are perverts Lifetime Supporting Member Joined Jul 30, 2018 Messages 16,239 Location Alabama Apr 6, 2021 #3 Yes or loose rear pinion nut, be checking.
OP 808jeeper Member Joined Apr 22, 2020 Messages 69 Location Oahu Apr 6, 2021 #4 AndyG said: Yes or loose rear pinion nut, be checking. Click to expand... Right on I’ll check it out. What’s the pinion nut socket size?
K Kid Mechanic TJ Enthusiast Joined Feb 15, 2021 Messages 750 Location Golden, Kalifornia-Lite Apr 7, 2021 #5 When I saw you started with “Howsit”, I immediately looked at your location. Nut size should be 1-1/8” or metric equivalent.
OP 808jeeper Member Joined Apr 22, 2020 Messages 69 Location Oahu Apr 11, 2021 #6 Hahaha Hawaii in the house! So I replaced all ujoints checked the nuts all good. Still getting the sound almost sound like a bad bearing
K Kid Mechanic TJ Enthusiast Joined Feb 15, 2021 Messages 750 Location Golden, Kalifornia-Lite Apr 11, 2021 #7 Haole in the house!
OP 808jeeper Member Joined Apr 22, 2020 Messages 69 Location Oahu Apr 11, 2021 #8 Kid Mechanic said: Haole in the house! Click to expand... You from the islands?
K Kid Mechanic TJ Enthusiast Joined Feb 15, 2021 Messages 750 Location Golden, Kalifornia-Lite Apr 11, 2021 #9 I lived there for a few years way, way back. Reactions: 808jeeper
