Just installed a set of halo headlights into my 2002 jeep TJ needing to wire up the turn signals and daytime running lights to do this do i need a special kind of wire or will any wire do thanks for any help and suggestions
Don't need anything special. Just make sure to secure it well and keep it away from the hot spots and moving parts.
If you want them as DRLs you'll need to run the main power wire to a fuse tap and choose something that is always powered when the engine is running. Then hook the turn signal wire to the nearby marker light.
I just hooked up main power to the marker light too, so the halos come on with those.
