I have a little 2.5 in my tj and i want to keep it a 4 cylinder so i was thinking about a stroker kit and super charger. Has anyone ever done anything similar?
I'd be interested in knowing how you get on with your Project.Motor mounts come from Advanced Adapters, Exhaust is a mixture of TJ aftermarket Banks Monster I already have on the Jeep and the Grand Cherokee Y pipe, CATS, O2 sensors etc. Blend the wiring of the two Jeeps by adding the Grand Cherokee extra wires for the V8 into the existing TJ Wrangler harness. The factory 2.5 or 4.0 fuel pump will run the Grand Cherokee 5.2 or 5.9L V8 just fine. All MOPAR, ALL COMPATIBLE with each other. Especially since my TJ has an automatic transmission in it, the 46RE transmission will fit and the shifter will control it.The cooling system will use the Jeep radiator since it is in great shape and works better than most aftermarket units with it's large aluminum core tubes. It has cooled much more powerful V8 engines in another Jeep I had.
I am thinking of doing a detailed write up on the swap when I start on it in earnest this spring when the days get a little longer and the rains stop. If I do, I will pay particular attention to the little details everyone else has neglected to show such as the electrical wiring and motor placement options.
Don’t bother upgrading the engine. A swap is a good option, on the other hand. Just saying with some minor work the 2.5l Jeep platform is great..
Also, what do you actually do with the Jeep. I’m assuming daily/ weekend warrior? I’ve run these jeeps on 33” and 35” (RAS) as daily’s for years before my current rig. Off-road I’ve also seen them play with the big boys.
I’ve oddly had very good luck with AX 5 transmissions. Good fluids, venting and yearly/ circumstancial fluid swaps.
Lose weight, not you, the Jeep. As much as possible. Maintain it well and it will last forever. It won’t break things as much as higher torque motors either. Personally I would swap the rear axle especially over 35” tires but plenty of 4L jeeps face the same dilemma.
